finding HU clipping rca volume, and setting gains on amplifier.Curious, what would you use it for?
Is this as accurate as any other exspensive $500+ oscilloscope? If it is I'll take it, just have to give me a bit to get the cash together. Don't wait up on me.
Setting my gains, aswell as what volume my RCAs clip at. I have them set with a DMM but I still feel like I might be clipping just a bit. My door speaker amp seem sinefficient, pushing the reccommended voltage with ohms law, it's set at 4.5v on the gain settings when its a 2.5v headunit. The subs amp gain is fine.Curious, what would you use it for?
This.finding HU clipping rca volume, and setting gains on amplifier. If you set gains via DMM, you can check if your amps clipping at that voltage.
OP: is there a reason your selling your oscope? i was thinking of buying the same one..
Edit: whoops, NOT OP.. meant bradl79
i have a JBL MS8 and u can't really use it on that, so i have not need for it anymore, i have an interested buy right now, i'll let u know if it falls throughfinding HU clipping rca volume, and setting gains on amplifier. If you set gains via DMM, you can check if your amps clipping at that voltage.
as far as i know it was pretty accurate, i did both a ddm and this and it was very closeIs this as accurate as any other exspensive $500+ oscilloscope? If it is I'll take it, just have to give me a bit to get the cash together. Don't wait up on me.
This.
