amp rack+AQ box
  • 2
knotdrummer88
hello, I just got my AQ 2200 in and I plan on building an amp rack and maybe rebuilding the box. well first, for the amp rack should I use mdf? or is there another wood(maybe cheaper) that would work just as good? I would either paint it or wrap it.
Second, When I do that I might build a new box. I love the lows, the box now hits the lows pretty good, its approx. 6 cu/ft and tuned to approx. 35-36 hz. If I lower the tuning instead of gaining any low end output will I just decrease my output on the high end? and the sub is the hdc3 18" copper coils
mdf is cheap, your other option would cost more unless you go with inexpensive plywood.
Your second question is impossible to answer. Generally all things being equal, a lower tune will give you a lower audible frequency and less overall SPL.
Thanks for all the advice. Ultimately, I was able to get them to honor the warranty contract. It took a lot of back and forth and I received...
7
179
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
12
225
The HU us likley 12-15 x 4 at best so yes, using an amp will be hugely beneficial, night and day. The HU us not going to drive a sub to any...
170
https://www.amazon.com/dp/B07DLC9M48/?tag=caraudiocom-20
25
411
knotdrummer88
knotdrummer88
Toledo, OH
diatribe
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
