For sale digital designs m1a and c4b package deal excellent condition
cleansoundzz
Buena Park
Digital Designs M1A mono block and C4B 4 channel. They were purchased brand new from an authorized Digital Designs dealer and come in the original boxes. The M1B does not come with the bass knob.
SPECIFICATIONS
Series C
Input Sensitivity 0.2V - 6V
Variable High Pass Filter 30Hz - 1.2KHz
Variable Low Pass Filter 30Hz - 500Hz
Variable Bass Boost 0-12dB @ 40Hz
Tested Voltage 14.4
Tested THD 1%
Model C4b
Cont Power at 4 ohm 60W x 4ch
Cont Power at 2 ohm 100W x 4ch
Cont Power at 4 ohm mono 200W x 2ch
Damping Factor >100
Dynamic Power 800W
Efficiency thru Output 65%
Dimensions - mm 244.5W x 54.3H x 300L
Dimensions - inches 11.81L x 9.63W x 2.14H
Signal to Noise >100dB
Shipping Weight 11.5 lbs
Input Sensitivity: 0.2V - 8V
Variable Subsonic Filter: 10Hz - 50Hz @ 24dB/Oct
Variable Low Pass Filter: 20Hz - 200Hz @ 24dB/Oct
Clipping Display: LED
Tested Voltage: 11.9 VDC
Tested THD: ≥1%
Cont Power at 2 ohm: 780W x 1ch
Cont Power at 1 ohm: 1200W x 1ch
Dynamic Power 14.4 VDC: 1905W x 1ch
Dimensions - inches 13.78L x 9.13W x 2.5H
Shipping Weight 16 lbs
Barely used for 5 months
$450 shipped for both FIRM and no trades
Very Nice!! I wished Id seen this two months ago. I ended up picking up a BNIB Sony XEC-1000. GLWS!! Ill chew on it a bit,and may pick it up??
i know that don’t change nothing thought i would share just let me know k if u want to text or email about it i will send u my info
959
e heard decent things, I've not used it, but for noobs, good place to start with that new DSP setup...
COMPLETED Full system sale
Changed my mind, the jetta is staying as-is and I'm buying the new car anyway, close this *****! Matt
cleansoundzz
cleansoundzz
Buena Park
cleansoundzz
    Apr 26, 2024
    Apr 26, 2024
