Eclipse deck + Ipod crazy question HELP plz!
LoudCrownVic
1/1 of Team Team Team
Hey
Got an eclipse CD8454 and a CD5423 (in diff cars) I want to be able to hook an Ipod to them...
I was told by a guy at Breast Buy that there are adapters that go through the cd changer sockets... Do these exist or am I out of luck hooking an Ipod to them? Neither have audio in cords but both seem to have AUX type functions.
Thanks a million, gotta go on some monster roadtrips soon iPod use would be choice!
Not sure about the cd changer adapter but for a quick fix just pick up an auxiliary cable at Radioshack. Theyre like $6 for a 6' cable. Its a cable with a headphone jack at each end. Plug one into your iPod and the other into the AUX input on the h/u. Then set your h/u to AUX mode. You can only use the iPod controls to select music, etc.
It may depend on whether you have Sirius or not. The reason that I say that is that I called Eclipse about hooking up my 5425 using the aux adaptor. the guy asked if I had Sirius, when I said yes then he said I would have to go through the CD changer connection and that I would not be able to view the song info.
I don't know if that helped or muddied the waters more, but you can call Eclipse and they will walk you through it.
THere are no aux inputs on either deck.
I tried every input on the deck to see if I could find one and none of them work. Just short of poking wires into the cd changer sockets. I am talking to eclipse but all I can get out of their online tech support so far is basic info... Seeing in anyone knew the awnser on here.
Very Nice!! I wished Id seen this two months ago. I ended up picking up a BNIB Sony XEC-1000. GLWS!! Ill chew on it a bit,and may pick it up??
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
I have a couple 3000s and 5000s and cant remember the other two right off hand, but these will not work with your unit that I can think of by...
792
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
LoudCrownVic
LoudCrownVic
Scales Bump, IL
WhoSayWho?
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
