tex512 10+ year member
SlowLoudAndBangin
Alright I'm pretty sure I found a good hitting system in my pricing range but wanted to make sure everything will work out with eachother when I buy it. That's where you guys come in and let me know if it will run smoothly or if I'm a fool. I plan on getting two 12" L7's (4 ohm). I'm going to power them with two hifonic amps 1200.1 at 1 ohm. (is 2400 watts too much to run my L7's at all day? Don't want to hurt em). And with knowing how I'm going to hook them up do I need to buy a certain type of amp kit for each since they will be wired at 1 ohm, or will them amp kit that they make for my amp be fine? I plan on getting two 2 farad copasiters to help out my battery. Should I invest in another battery or will mine hold up with the copasiters helping it out? If it's causing my subs power I will have no problem buying a better battery. If so what battery would you suggest? Wanted to post a final thread before I make the purchases. I appriciate everyones help with my system on here. Thanks
