WTT: 2 1800w Amps for Wii or Ipod stuff
bajalion
Or maybe some other Non Car audio stuff. I'm up to my neck in Amps and Woofers
Class X 1800W Digital Amplifier
The only 1 Ohm Stable Class X mono Block Amplifier on the Market!!! These amps are as serious as they look. Full LCD read out displays amplifier Voltage and Temperature. Two MA Audio Class X amplifiers can also be bridged togehter at 1 ohm to combine their output power. This is another exclusive feature by the MA Audio Class X Amplifiers.
Although the listed Power Ratings have been measured at 14.4 volts, this amplifier is capable of accepting up to 17 Volts DC. This will increase RMS output power by 300W for each load listed below.
SPECIFICATIONS Model SY7011DX
RMS Power @ 14.4V
4 Ohm 750W
2 Ohm 1000W
1 Ohm 1500W
MAX Power @ 14.4V
4 Ohm 1000W
2 Ohm 1500W
1 Ohm 1800W
Signal to Noise Ratio >96dB
THD Level
4 Ohm 0.5%
2 Ohm 0.5%
1 Ohm 1.0%
Frequency Response 10Hz - 350Hz
24dB Low P ass Filter 50Hz - 350Hz
24dB Subsonic Filter 15Hz - 50Hz
Bass Boost Control at 45Hz 0 - 18dB
RCA Input Sensitivity 0.2 - 8V
Low level Input Impedance 22K Ohms
Damping Factor 200 @ 4 Ohm
Fuse Rating 40A x 4
Dimensions (W x H x L) 11.6 x 2.56 x 16.73
bajalion
bajalion
Akron, OH
bajalion
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
