Wisdom teeth :(
imaspaceguy90
LOUDS10BLAZER=SCAMMER
Hey guys my left back tooth has beenhurtin, i feel a new tooth back theree starting to come threw my gums, Im pretty sure its a wisdom tooth. my right side doesnt hurt at all. Will i have to get this tooth puttled or is there a chance its just one and i can keep it there? Im only 15 and 9/10ths i shouldnt have to deal with this, lol
mine started hurting, but it hasnt since...the dentist told me i needed to get it pulled, but he said if it doesnt bother me anymore i dont have to worry about it...give it some time adn see how you feel
no one cares pelota //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
but at least you still have your ****** and whips //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
my grandfather just turned 64, and after the first time they bothered him, they never gave him any more trouble...
Of course there are exceptions to everything, one of my friends grandfathers has smoked for like 60 years and doesn't have any problems. My point is it's stupid to not have them removed nowadays, as the chances of them causing problems in the future are greater than not. And if you get them removed later in life it's a more painful process, the risks are greater, and healing takes a much longer time. Plus getting them removed is a relatively painless process, I had all 4 taken out when I was 17 and was good to go within a day.
i guess i shoud stop putting it off then...
yea, but i heard it hurt like hell
If they put you under there's no pain during the process. I woke up from mine in another room with gauze in my mouth and I looked like a walrus, but there wasn't much pain. I couldn't chew for a day and my mouth was a little sore, but it was pretty easy.
From a quick google search:
http://www.umanitoba.ca/outreach/wisdomtooth/wteeth.htm
Why Should an Impacted Wisdom Tooth be Removed if it Hasn't Caused any Trouble?
Impacted wisdom teeth are almost certain to cause problems if left in place. This is particularly true of the lower wisdom teeth. Such problems may occur suddenly, and often at the most inconvenient times.
When is the Best Time to Have my Wisdom Teeth Removed?
It is now recommended by specialists that impacted wisdom teeth be removed between the ages of 14 and 22 years whether they are causing problems or not. Surgery is technically easier and patients recover much more quickly when they are younger. What is a relatively minor operation at 20 can become quiet difficult in patients over 40. Also the risk of complications increases with age, and the healing process is slower.
http://www.colgate.com/app/Colgate/US/OC/Information/OralHealthBasics/CommonConcerns/WisdomTeeth/ShouldYouHaveYourWisdomTeethRemoved.cvsp
Even if your wisdom teeth aren't causing any pain or other problems, chances are they will cause problems at some point. The most common problems are decay, infection, and crowding or damage to other teeth. But more serious complications can occur, including the development of a cyst that can cause permanent damage to bone, teeth and nerves.
Removing wisdom teeth is easier in younger people because the tooth roots are not fully developed and the bone in which the teeth sit is less dense. Extracting your wisdom teeth before any complications develop also allows for shorter recovery time and less discomfort after the surgery.
Ill stick to the green, im already fat, i dont wanna have to get swollen, never tried gas tho
the gas is nice...nothing better then a full tank..//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif Its even fun at the dentist, though not as much fun as having your own tank. Some dentist will give you a sedative hypnotic like halcion or valium. Either way its ok with me //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
imaspaceguy90
imaspaceguy90
Melbourne,FL
Lil Poot
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
