Reply to thread
Car Audio Discussion
Wiring a 2000 Watt amp
Message
<blockquote data-quote="n2audio" data-source="post: 94853" data-attributes="member: 540940"><p>Allrighty...Rating: 500 rms x 2 at 4 ohms -- let's be nice and say it's going to put out an actual 400 x 2</p><p></p><p>At 2 ohms, MAYBE it will get you 600x2 (or 1200x1 bridged @ 4 ohms). That's best case cenario.</p><p></p><p>Personally I think 4 ga. (properly fused) would cover you, assuming you don't have an enormous length of power wire. At least 4 is what I'd use. If you blow an 80 or 100A fuse you know you need to upgrade.</p></blockquote><p></p>
[QUOTE="n2audio, post: 94853, member: 540940"] Allrighty...Rating: 500 rms x 2 at 4 ohms -- let's be nice and say it's going to put out an actual 400 x 2 At 2 ohms, MAYBE it will get you 600x2 (or 1200x1 bridged @ 4 ohms). That's best case cenario. Personally I think 4 ga. (properly fused) would cover you, assuming you don't have an enormous length of power wire. At least 4 is what I'd use. If you blow an 80 or 100A fuse you know you need to upgrade. [/QUOTE]
Insert quotes…
Verification
Post reply
