what would sound louder 15'' or 18''
hasnt this been argued and discussed on here several times before with newbs, just search it cause I know theres enough info here for you on that
newbes umm no the only reason i asked is because i nevre had or heard a 18'' before
and if you consider having 4 15'' cvr with two alpine v12 1000.1 amps newbe than i guess i am and im actually looking into fi audio if that what a newbe looks for than yes again i am
newbes umm no the only reason i asked is because i nevre had or heard a 18'' beforeand if you consider having 4 15'' cvr with two alpine v12 1000.1 amps newbe than i guess i am and im actually looking into fi audio if that what a newbe looks for than yes again i am
yes I would consider someone running 4 cvrs on two alpine 1000.1s a newb.
Glad your looking at FI it will be a nice change. I bet ya if you get a single BTL and run one of those amps on each coil it will beat your 4 cvrs //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
should i get the 15 btl or 18 btl
were you the guy that stacked two prefab sealed boxes on your back seat and called it a wall?
what do you have for a vehicle, a lot depends on if you have sufficient air space, I wouldnt throw a 18 in the back of a small trunk if thats what you were planing on/
i have a Nissan pathfinder
i was able to fit 4 15'' in a ported box before they jacked me(because of my neglect)
i have a Nissan pathfinderi was able to fit 4 15'' in a ported box before they jacked me(because of my neglect)
I got a 4runner, which is about the same size, I doubt I could comfortably fit 4 15"s in it though atleast not with the batts and amps. If you plan on moving up to bigger and better I would suggest you look into upgrading your electrical first. Cant run a pair of BTLs off of a stock electrical.
youngcoke
Banned
youngcoke
chicago
Platestacker45
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
