Sold PG 215ix 15band eq, cross, line driver ect... CHEAP! $115 shipped
desertheat
Reason for sale...... I have a new deck with time alignment and built in parametric eq. My system is tuned well enough that I am not in need of this much eq.
Condition... It is 100% flawless working order. Cosmetics are a 9.9/10. Only thing on it that comes to mind is 1/2 of the tip of an eq slider was chipped but looking straight at it you cannot even see it, bairly noticable. Last is one of the outer rca sheilds on the aux output came loose and was lost. I cut up and rca and repaired it with ease but it is silver color instead of gold and when an rca is plugged in, it is not noticable. Again everything works FLAWLESS!!!
Features are
DUAL 15 BAND NARROW Q EQ
24DB/OCT VERIABLE HIGH / LOWPASS EQ
COMES WITH LPL44 CONTROLLER "BASS CONTROL ON DASH"
IS AN 8V LINE DRIVER WITH LED OUTPUT METERS
HAS FRONT, SUBWOOFER AND AUX OUTPUT.
Sub delay "form of time alignment
AUX OUTPUT HAS A SELECTABLE SWITCH FOR BANDPASS FROM 250-15kHZ. AUX OUTPUT ALSO HAS A MONO SWITCH FOR CENTER CHANNEL USE OR REAR FILL USE. FRONT AND AUX OUTPUTS HAVE EQ DEFEAT SWITCHES.
ALL CHANNELS HAVE INDIVIDUAL GAIN CONTROLS
Bottom line, this is one bad arsed unit, new was $499.99
DO NOT CONFUSE THIS UNIT WITH THE CHEAPER, LESS FEATURE PACKED TEQ15, THIS EQ BLOWS IT AWAY!
If I can get $115 shipped for it then it is sold. Hit me up at desertheatracing@yahoo.com
desertheat
desertheat
Tempe, Az
DBfan187
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
