This is a JL Audio E1400 500w Mono Sub Amp.This Amp is well under rated as is most JL Amps. This Amp will give you close to 600w, and it is VERY clean sound! I bought it brand new a few months back but I ended up buying another 12W6 so I had to get a bigger amp to push both subs. This amp is in MINT condition as you can see in the pics. Its still in the box with the owner's manual. I only had the amp in my Explorer for 6 weeks. Please make an offer, all reasonable offers will be considered. Please PM me with offers.
JL Audio e1400D
500 watts, Class D Monoblock Amplifier
Class D Monoblock Full Range Amplifier
High-Damping Class D Circuit with discrete contorl circuitry
Pass-through RCA outputs
On-board crossover: Variable Low-Pass Filter: 20 -200Hz, Selectable Slope
High level inputs
CEA-2006 Compliant
RMS Power Rating (14.4V):
4 ohms: 320 watts x 1 chan.
2 ohms: 500 watts x 1 chan.
Frequency Response: 10 - 250Hz
Damping Factor: >500 @ 4 Ohms / 50Hz,
Input Range: 200mV - 8V RMS
Bass EQ: +6dB Fixed Frequency, Fixed 'Q' with port for optional remote bass control
Dimensions: 11.81" L x 9.25" W x 2.36" H
JL Audio e1400D
High level inputs
CEA-2006 Compliant
