Fi Q - 1ohmDVC vs. 2ohmDVC
CadillacMatt
Disturbing the Peace
Hey guys, I'm looking at 2 15" Fi Qs, but I don't know whether I should spring for the 1ohmDVCs or the 2ohmDVCs.
The amp I'm eyeballing is the AQ 2200D, which puts out 1300wRMS at 2 ohms, and 2200wRMS at 1 ohm... amp is 1 ohm stable.
Now I could wire the 1ohm subs to a total 1 ohm load on the amp, and the 2 ohm subs to a total 2 ohm load on the amp... which would be better? Would the 1 ohms simply play louder?
These subs are rated at 1000W but I plan on getting the BP Power option and these aren't for competition so I won't necessarily be beating the living daylights out of them. Can anyone help me or explain the difference? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Get dual 1's, you can always turn the gain down if you run into problems with that Amp
So a lower load really is a better way to go if your amp can handle it then, right? Because you have more power available but you can always dial it down?
The only thing is I might not need to upgrade my alternator with the 1300W, but for sure with the 2200W... that's a lot of juice //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I went with two DVC 1-Ohm with a AQ 2200d, exactly the same setup as yours. I only need the gains just a tad over half to get a good amount if not maybe too much sound from those subwoofers at 23/35 on the volume knob.
No bass boost or anything else and those subwoofers can really tear apart the cab of my truck on heavy bass or hip hop songs while retaining a lot of responsiveness on less-bass demanding songs.
Ok thanks I'm glad you have some first-hand experience I can use... how about your electrical? Is it stock or do you have any upgrades? Thanks
CadillacMatt
CadillacMatt
San Antonio, TX
thorshammer1
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
