Crossfire CFA30HC - Don't see these too often
Goindef154
Nothing
Crossfire CFA30HC
I'd give it an honest 7.8/10 it's not great but I cleaned it up real nice and it's in pretty good shape for the age.
I have heard that though it states 640 @ 1 ohm it does closer to 1000 but obviously I don't have the equipment to prove that.
Specs(Thanks to LoudCivic):
CFA30HC
Power 4 ohms .008%THD: 15 watts x 2 30 watts x 2
RMS Power 4 ohms@0.02%THD*: High Power- 60 watts x 2
High Current- 35watts x 2
High Power- 120 watts x 2
High Current- 65watts x 2
RMS Power 2 ohms@0.02%THD *: High Power- 110 watts x 2
High Current- 60watts x 2
High Power- 210 watts x 2
High Current- 120watts x 2
RMS Power 1ohm@0.02%THD *: High Power- 185watts x 2
High Current- 110watts x 2
High Power- 320watts x 2
High Current- 210watts x 2
RMS Power .5 ohm@0.02%THD *: High Current- 185watts x 2 High Current- 320watts x 2
Maximum RMS Bridged Mono
0.02%THD:
High Power- 370 x 1 @ 2ohm
High Current- 370 x 1 @ 1ohm
High Power- 640 x 1 @ 2ohm
High Current- 640 x 1 @ 1ohm
Bandwidth: 11Hz – 38Khz 11Hz – 38Khz
Selectable 12dB Crossover: LP/FULL/HP Variable 45 – 150Hz LP/FULL/HP Variable 45 – 150Hz
RCA Preout: Yes Yes
Bass Boost: Variable: 0 to+12 dB @ 45Hz Variable: 0 to+12 dB @ 45Hz
Signal to Noise: >100dB >100dB
Channel Separation: >70dB >70dB
Input Sensitivity: 340mv to 5.2 volts 340mv to 5.2 volts
Input Impedance: 20K ohms 20K ohms
Damping Factor: >400 >480
Dimensions: 9.6”W x 2.0”H x 13”L 9.6”W x 2.0”H x 18.5”L
$175 shipped
Price includes shipping and insurance through USPS Priority.
For buyer's information Crossfire rate all of their amps at 12.5v. This amp is pretty hardcore and counts as a "cheater" amp because it probably does close to 1200 watts at low impedance.
This can be used for mids/highs too(it's class AB) if you have like, 4 pairs of component sets or more and it'll make your speaker beg for mercy.
Goindef154
Nothing
Goindef154
Phoenix, AZ
Goindef154
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
