Sold Convert MKV to other video formats like MP4, FLV, AVI, WMV, 3GP, etc.
tutubebe99
Banned
USA
About MKV files:
Wikipedia gives an explanation of it as: "The Matroska Multimedia Container is an open standard free container format, a file format that can hold an unlimited number of video, audio, picture or subtitle tracks inside a single file. It is intended to serve as a universal format for storing common multimedia content, like movies or TV shows. Matroska is similar in conception to other containers like AVI, MP4 or ASF, but is entirely open in specification, with implementations consisting mostly of open source software. Matroska file types are .MKV for video (with subtitles and audio), .MKA for audio-only files and .MKS for subtitles only. The most common use of .MKV files is to store HD video files."
Although MKV files have been one of the most popular video formats, most portable devices, video players, video editors, etc. do not give native supports to them. Therefore, it’s necessary for us to convert this format to many other media formats, so as to play or edit them without trouble.
How to convert MKV to other video formats like MP4, FLV, AVI, WMV, 3GP, etc.?
Software you need:
Pavtube MKV Converter
Step 1: Click "Add" button to load MKV files.
Step 2: Click the drop-down list of "Format" to select an output format, which format to select depending on your end use of the generated files. Meanwhile, click the folder icon at the end of "Output" to specify a destination folder.
Step 3: Click "Settings" button to adjust video and audio parameters like aspect ratio, bit rate, frame rate, sample rate, etc.
Step 4: Click "Convert" button to start conversion.
Tips:
1. If you want to combine multiple MKV files to be as one file, please tick the checkbox "Merge into one file".
2. Click the camera icon, and then you can take screenshot of the playing MKV file, after that, click the folder icon on the right side of this icon to get the screenshots.
3. Click "Edit" button, then you will be led to the editor interface as below:
The "Crop" function allows you cutting off black edges and the unwanted areas of the original MKV files.
The "Trim" function enables you to set the exact duration of the video clip. You can set the "Start" time and "End" time, or you can directly drag the slide bar to the time points as you like.
Through using "Text Watermark" and "Image/Video Watermark" function, you are able to add your preferred texts, pictures, even GIF animations and videos to be as your watermark, in that way, the "Picture-in-picture" effect will be realized beautifully.
The "Effect" function permits you adjusting the effects of your MKV files, including "Brightness", "Contrast", "Saturation", and adding special effects like "simple gauss blur", "Simple laplasian sharpen", flip color", etc. to your videos.
"Audio Replace" function makes it possible for you to take place of the original audio with your specified audio source.
Tanbee Video Converter for Mac is a powerful and easy-to-use mac video conversion software which helps you convert videos and audios between various formats for Mac easily and fast, such as AVI, MP4, MOV, MKV, WMV, MPEG, 3GP, VOB video and camcorder video formats like AVCHD (MTS/M2TS), MOD/TOD, etc.
Tanbee Video Converter for Mac makes most video files playable on the iPad, iPod, iPhone 4, Apple TV, BlackBerry, PSP, Palm, iRiver, GPhone, etc. An easy way to enjoy your videos, movies and TV shows anytime and anywhere. This Mac Video Converter can also extract audio from video, movie and convert audio to audio, like MP3, M4A, AAC, etc.
Join multiple video clips together; Clip the required segments from your video, either output them separately or merge and output them as a single video.Crop the image to remove unwanted backdrops, black borders or emphasize a particular focal point; Adjust video brightness,contrast and saturation; add different artistic effects to make your video look special.
More Info:
tanbee.com/video-converter-for-mac/
More Info:
Code:
iPad Software Pack for Mac
iPad Software Pack for Mac is specially designed iPad software tools for Mac users. It contains all powerful iPad software: iPad Video Converter for Mac, DVD to iPad Converter for Mac, iPad Manager for Mac, and iPhone Ringtone Maker for Mac.
iPad Video Converter for Mac is a professional Mac iPad Converter designed only for Mac users. The best iPad video converter for Mac can convert all the videos to iPod, iPhone and iPad video and audio formats.
DVD to iPad Converter for Mac enables you to enjoy DVD movies on your iPad anywhere and anytime. It is the best DVD to iPad Converter Mac software designed for Mac users to rip DVD movies to iPad for Mac.
iPad Converter Suite for Mac
If you are a super iPad fan, iPad Converter Suite is definitely your best choice. This software pack integrates three useful software, including DVD to iPad Converter, iPad Video Converter,and iPad Transfer.
iPad Manager for Mac is really an all-in-one tool for iPad users. This iPad Manager can both backup the audio, video, image files on iPad to Mac and import audio, video files or folders, photos to your iPad.
iPad to Mac Transfer
iPad to Mac Transfer is designed for Mac users to backup the files on your iPad/iPhone to the local disk of your Mac. This iPad to Mac Transfer can copy your selected video, audio and image files to your Mac immediately without any loss.
iPad ePub Transfer for Mac
This ePub to iPad Transfer can directly import the pop open book format-ePub on your local disk to iPad. It means that you can directly transfer ePub to iPad while you connect iPad to Mac and operate this transfer.
More Info:
Code:
on-mac-os.com/ipad-tools/
tutubebe99
USA
jason39
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
