8in sub for truck
I had a pair of rex8 " subs in a sealed box - powered them with 320w. did not satify me
but i expect alot
so they might work ok enough for you - they aint too deep I remember... maby
check out parts express. they show all the specs on their stuff so you can find the mounting depth on it.
http://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=847
or you could make mdf rings to mount to your box to add height so the sub motors dont bottom out in the box.
T3 Audio T200-8s 8" Single 4 Ohm 400 Watt Subwoofer
I just picked up of pair of these to use as midbass duty.
I built a box of 0.5 cubit feet to test one in with only 125watts.
It's a clean sounding sub. yes i was very surprised tat T3 Audio is known for there SPL.
I didnt think they could make a SQL sub.
When i tested this sub i use Hip-hop, Jazz, Rock, & Techno.
I do have this weird Bass tone CD that a friend gave to me.
This little sub is a beast, the RMS is 200- peak 400 @ 4ohms.
One thing i love about this sub it didnt distort, it had clean tight bass, & it got loud off of 125rms.
I had it bandpassed at 150 lowpass-50highpass, I was told it can go down to 35hz.
I cant wait to built my kick pods or i'm thinking of placing them in a tube under the passenger glove box.
you donrt like them you can return them for your money back.
At $39 a sub this is probably the best 8inch sub i've bought.
Last week i talked to someone at T3 Audio & yes they are warranting there subs.
They are about release 2 other 8 inch subs that will beable to take more power .
Write your reply...
SpedBoy
SpedBoy
Brighton, Mi
okiedokie
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
