Sold 2 Hifonics Brutus Bxi2608ds, 2 Kinetik Hc2000s and a memphis line driver
2loud4youmorris
=====AMPS=====
Class D Monoblock Amplifier
RMS Power @ 4 ohms: 850 watts x 1
RMS Power @ 2 ohms: 1700 watts x 1
RMS Power @ 1 ohm: 2600 watts x 1
Peak Power: 5000+ Watts!
1-Channel Mono-Block Operation
Super D-Class Amplifier Topography
Ultra-Fi MOSFET Outputs
Illuminated Hifonics Logo
PWM MOSFET EXVP (Exponential Vari-Power Supply)
SPC-Twin Turbo-Torroids with Simpatico Coil Design
Fully Adjustable Accu Cross Crossovers include:
- 24 dB Subsonic Filter (Adjusts 15 Hz to 35 Hz)
Phase Shift Adjustments, (0 to +180-Degrees)
24 dB Low-Pass Crossover (Adjusts 35 Hz to 250 Hz)
Bass Boost: Variable Bass Equalization (+ 10dB @ 45 Hz)
Remote Bass Control Included
Balanced Line INputs w Optional Hifonics MM-BLD1
Gold RCA Line Outputs:
Permit Amplifier Daisy-Chaining
(0.2v to 9-volts Signal Level)
0-Guage Power Connectors
Dimensions 17.72" L X 2.52" H X 9.45" W
=====Batteries=====
AGM Technology
* Sealed Non-Spillable Design
* Mount In Any Position
* Ultra Low ESR
* More Plates For Stronger Energy Density
* Higher Voltage Under Load
* Tightly Packed Cells
* Superior Heat & Vibration Resistance
3. Description/Condition: Good/great working condition.
Line driver has a scratch on the left side as seen in the pics and the amps have a little chrome discoloration but everything works great. Only used everything for 3 weeks. Batteries are in great shape.
4. What you are looking for: :2 Sundown SAZ-3000D's
But if you have anything else let me know.
Or I would like $350 for each amp OBO
$250 for the batts OBO
$50 for the line driver
PICS ARE ON HERE
http://www.caraudioclassifieds.org/forum/showthread.php?t=5623
2loud4youmorris
2loud4youmorris
Caro, Michigan
schackel
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
