Zed Leviathan 6channel V2
Krieger88
Cosmetic 9.5/10 Functionality 10/10 , Had to have 3 broken capacitors repaired by Zed and had the amp professionally tested before it was sent back to me.
$550 firm
I'll pay shipping
Item Pictures: View attachment 26544329View attachment 26544330
Amp Specs:
Continuous Output Power into 2 ohm: 300w x 6
Continuous Output Power into 4 ohm: 150w x 6
Typical Output Power into 4 ohm per channel (1% THD): 180w x 6
Continuous Output Power 3 pairs of channels bridged into 4 ohm: 600w x 3 Channel pairs may be bridged independently
Continuous Output Power 2 channels bridged into 8 ohm: 300w x 3 Channel pairs may be bridged independently
Minimum Speaker Impedance: 2 ohm per channel
Minimum Speaker Impedance in Bridge Mode (2 channels): 4 ohm
Power Response at any power into 4 ohms: 10-60KHz -2dB
Frequency Response at rated power into 4 ohms: 10Hz-30KHz -0.1dB
Input Voltage range for rated power into 4 ohms: 0.25 to 8.6 volt
Input Impedance at 2KHz: 47K ohm
Noise below rated output (30KHz limited): -100dB
Channel separation at 2KHz: >80dB
Damping Factor at 20Hz with 4 ohms: >80
Total Harmonic Distortion with 4 ohm 20Hz-20KHz
From 1 watt to rated power. Typically less than 0.05%:
Intermodulation Distortion:
Phase response at 20KHz: Lagging 12 deg
Slew rate (volts per micro second)-In”Flat” mode: 12
High Pass Crossovers (24dB/octave) Channels 1+2 and 3+4: 55Hz-4KHz
Low Pass Crossovers (24dB/octave) Channels 3+4: 55Hz to 4KHz
High Pass Crossovers (24dB/octave) Channels 5+6: 10Hz-105Hz May be used as a Sub Sonic Filter
Low Pass Crossovers (24dB/octave) Channels 5+6: 40Hz to 235Hz
Protection - Short Circuit, DC, Thermal: Yes
Power Source: 10-14.5v DC Negative Ground
Current Consumption with Sinewave at 4 ohms: 94A
Current Consumption with Music at 4 ohms: 18 to 28A
Idling Current:
Fuse rating with 4 ohm load: 30A-40A depending on usage
Fuse rating with 2 ohm load: 40A -80A depending on usage
Size W x H (247mmx55mm/9.7”x2.1”) x L: 410mm/16.14” Excludes connectors
Shipping Weight (Kg/Lbs): 5.9 / 13
Made in USA
that is an amazing piece you have sir. Would love to do a direct swap with this and my ppi art 6ch. Your amp is worth every penny asked for sure.
how did u break the capacitors and any warranty from zed ? also any trades ?
I don't know how they broke to be honest as there wasn't any sound quality difference and nothing was cutting out or anything. The former buyer had noticed before hooking it up and I had to send it to zed to have it repaired. I bought it bnib from someone on a forum so there was no warranty for me.
  • Locked
I don't suppose you have a spare Zed mikro IV in your collection? I'm conveniently located in central Florida and have cash on hand, lol. Matt
6
3K
Krieger88
Krieger88
Medford, ny
Krieger88
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
