Zapco SP7-SL Equalizer.
  • 3
Zapco SP7-SL
Like new, Works as it should. Comes with EQ, Power Supply and cord.
Will also trade for a mono amp 3K and up, can add cash for right amp. Please no junk !
Features:
Max. Output Level / Balanced: 16 Volts
Input Impedance: 10K ohms
Output Impedance: 600 ohms
T.H.D. + Noise:
S/N Ratio: 100dB
Frequency Response: 2Hz - 150KHz
Stereo Separation: >80dB
Dimensions: 3.25"L x 6.25"W x 0.95"H
SymbiLink™ Balanced Input
Can drive 600 ohm loads
Pro audio balanced differential Inputs
High quality PC board with ground plane
Very low noise & Distortion
Clipping LED’s monitor all 28 op-amps
1/2 DIN size
Surface mount technology
Separate gain switches for both input and output
Seven 1.25 octaves of Equalization
Can accommodate 8 volt (16 balanced) input / output signal levels
Very high quality, long life, low noise potentiometers
SP7SL - Zapco SP7 SL SymbiLink Seven Band EQ with Gain
$350.00 Shipped in the usa.
Does this only work with zapco amps, or is it compatible with other brands? With the new decks that have built in equalization, is this piece a much cleaner equalizer? Tell me why I need this because I am interested...
With the Included power supply, It will work with any amp.
A classic piece with great sound quality and transparency in sound with minimal coloration. All EQ bands boost and cut frequencies with a beautiful full sound and do not make the sound peaky and unnatural.
This is a great addition to any high quality system that will allow you to make quick EQ changes on the fly depending on the type of music you are listening too.
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
I follow a guy on YouTube called PS sound he's a high-end car stereo installer in the UK yeah I'm talking like super high-end cars and expensive...
10
I may get a pair of his 6" woofers for the back. It's an extended cab pickup so the enclosure won't be as bad as a door with holes in it. Highs...
13
3K
  • Locked
COMPLETED Zapco SX6 SQ
This Amplifier is Pending. Yet still available to purchase until sold.
miller83815
Hayden, Idaho
miller83815
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
