WTF!!! Bronco Big 3
  • 4
ObTechAudio
Provo, UT
Ok, I'm trying to do the big 3 on my buddy's full-size 1992 Bronco 5.8L Windsor, but I am absolutely stumped. The alternator doesn't have a post and plug like I'm used to. It only has two plugs identical to the photo below. Any thoughts on how I can do the big 3? Where the (+) would go?
[/img]
Pull out a digital multimeter. Set it to DC 12v. If the two posts you test read a negative value, then you know your leads are backwards. Likewise if the two posts read a positive value then whatever post your red lead is on is indeed the positive.
No, no, no hahaha I know which plug is (+) and which is (-) my problem is they are plugs like wiring harness plugs, not posts. With the traditional post, you can simply slip an O-ring terminal on it and tighten it down with a nut. These, being plugs obviously can't do that. So how can I connect my huge (+) big 3 wire to a plug in the pictures? Can't put an O-ring terminal on a plug (scratching my head)
Before doing the big 3 on that bronco, swap that alt with one from a mid 90s Taurus IIRC. Known as the "3g swap". Just have to splice in the 3g alts harness and a plug and make a notch in the broncos alt bracket. Pretty easy to do and it makes a good difference when I did it on mine.
Search "bronco 3g swap" for all the info you need.
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
Im not a fan of S.Down, and everyone knows why. I wouldnt buy a screw from them. #1. The enclosure is everything when it comes to the performance...
26
3K
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
ObTechAudio
ObTechAudio
Provo, UT
CJL
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
