Looking for this amp, thanks:
Power
6 X 75 @ 4 Ohm
6 X 150 @ 2 Ohm
4 X 150 + 1 X 400 Max Power
Freq Resp 20Hz-25Khz
SN Ratio >103dB
THD
Damping>200@100Hz
Channel Sep>65dB
Dimensions (LxWxH) 19" x 10" x 2"
The Z6000 is the perfect amplifier for either a DTS or Dolby in-car theatre entertainment system. configurable for operation with three,two,or even one pair of RCA inputs. the center channel has its own discrete input or can be phantom created by simply sliding a switch. the subwoofer channel is high current-2 ohm stable and comes standard with a bass remote control
Also Available in Black
Power
6 X 75 @ 4 Ohm
6 X 150 @ 2 Ohm
SN Ratio >103dB
THD
Damping>200@100Hz
Channel Sep>65dB
