Would this relay be suitable for parking brake bypass on Pioneer avh-2400bt
  • 5
alecx
Hey all,
I know the Pioneer AVH's need a Relay for the parking brake bypass to work (as it cant see ground when it comes on or it will fail to work)
I am just wondering, would this relay I have found be fit for purpose?
maplin co uk sealed-reed-relays-2605
Reed Relay 12V SPST
Also, I have heard it is wise to put a diode in on the amp power on wire. Would any do? For example:
maplin co uk 0.5w-zener-diodes-19089
Thanks to any one that can help //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'd recommend getting a Microbypass instead. Much easier to fit behind the HU when all is said and done. Mine has worked great since October.
Are these "Microbypass" things just smaller Relays? Like the reed relays i found? Would a SPDT Reed Relay do the trick, is there any reason not to use one.
if not what is the microbypass, does any one have schematics for it?
thanks for the replies so far!
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
That doesn't make any sense. The directions say to hook it up to the parking brake. The parking brake is engaged when the car is off. You...
17
7K
Man..Id like to see how it turns out as well.
16
3K
Hi all my first post here ,.... I just purchased A Halo 9 F905D which I am installing into my Renault Master 2009 based motorhome,...... My first...
alecx
alecx
England, UK
Loudmp5
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
