Wiring power and Ground quick Questions
  • 3
soundnoob
Iv got a quick noob question about wiring does the ground wire have to be the same size as the power wire? my runs will only be about 6ft and i was looking at 6ft of 1 gauge power wire and then 4 gauge for the ground would that affect anything? also if i was to use OFC for the power and CCA for ground would that have any effect?
the set up it self is going to be a ed nine.5 and a 1500w inverter so the 1 gauge ofc up to a distro block with 150a fuse, then to 4 gauge to amp/inverter. Then the 4 gauge up to a ground distro to amp/inverter
that sound like it will work? or should i use 1 gauge ofc for both power and ground up to the distro's?
Test question for CA.com
Since current is defined as charge flow, which direction is current (charge flow) in a DC electrical system?
A. Positive to Negative
B. Negative to Positive
C. Neither, it is alternating
D. Not Sure
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
11
Some at DIYMA and other places have tried this Oscilloscope as well and got good results shockingly for such a cheap unit...
8
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
223
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
629
soundnoob
soundnoob
Moncton NB
keep_hope_alive
