countrygunner
Ok I'm kinda in a pickle. I've got two sa 12 dual 2 ohm subs right now. I have them on kicker cx1200 amp. I've seen Dino results showing the amp does almost rated certified, like 1150 or something. I'm still thinking the subs need more. Problem is most of the amps I'm looking at like the saz 2000 and so on are 1 ohm stable amps and don't put out enou 2 ohm to change.
So here are my questions:
1) do I get a bigger amp that will put out around 2000 watts at 2 ohm like the saz-3500? How much will I have to upgrade my electrical for this amp? I have a factory 180 amp alt and have no problem with the cx1200.1 and cxa300.4 kicker amps I have now. It runs about 14.5 constant and never dips below 14 when running above just idle.
2) second option is, if I can do this, get two saz-1000 amps and strap them. Running one sub per amp at one ohm each. Would this be better on my electrical?
3) get an amp like the saz-2000 and run it half ohm but don't cut it wide open as this will be a daily system. I'm assuming to do this I would have to upgrade to at least another battery and maybe alt.
Help would be appreciated. Oh and I'm running the subs in 1.5 ft3 after displacemnent roughly per sub ported.
