Wiring 4 speakers on 2 channels?
  • 2
its a 4 channel amp though.....
so if i run 4 speakers on 2 channels, where shhould i set the gain so that all 4 speakers are getting good power?
if you have a DMM you can set it to whatever rms the speakers take. if you don't have a DMM just turn up the gain until you hear distortion.
Also a 4channel amp is really just 2 2channel amps in one chassis in most cases. So think of your amp as 2 2channels since that is how you will be using it
I have a jeep wrangler 2010 4 door.. So 2 of my speakers are in the dash upfront. And the other 2 are in the bar in the middle of the car
6
For clarity, why not example 2 ? Example 2 is 2 ohm...my speakers are 4 ohm and amp uses less RMS wattage with the bridged 4 ohm full range...
Guess so Spokey! Guess we have all been ripped off then! Whatever this guy is smoking he needs to really lay off. Either that or quit going out...
18
papito
papito
FL
thegreatestpenn
