Wiring 3 amps?
cbuts
Hey there getting ready to install a third amp.
I've read it's suggested to add a relay for the remote wires ?
Is this necessary? Factory stereo with dsr1 installed ,
Taramps 4 channel 1200 RMS
Pioneer 500 RMS
Taramps Md 3000.
I was just going to piggy them off the two amps now like they already are ...is that ok??
Thanks 👍
Just reading this.. having my dsr1 DSP.. would I still need a relay??
Thanks very much for the reply..
Why is this though ? Because of the dsr1 able to put out more remote wires ?
Thanks !
I have 3 amps, that use the same remote wire. I have No dsr1. The dsr1 is not the reason you are able to splice the remote wire. I hope I understood your question. You can PM me if you need further explanation. The quick answer to your question is that the remote wire is sending a strong enough voltage that it will turn on your amps.
Just ignore Red...he's wealth of useless to dangerous advice...all without knowing what he's talking about
19
You can try that Seat Bolt for a ground location. Remove all paint down to Metal. Place a Washer then One amps ground Ring terminal(copper..sand...
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
151
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
556
cbuts
cbuts
canada,ont
huberoy123
