Wire my 5 Channel Fosgate amp??
  • 2
Wire your subs parallel for a 2 ohm load. Wire the speakers to the amp, 1&2 for the front, 3&4 for the rear. Read up on setting gains. .........
Yes but how do I put out more to the front speakers? They are 100 watts, and it says it can only put out 50 at 4 ohms and 75 at 2 ohms... I'm just wondering how I can put out the 75 while still amplifying the rear speakers as well.
Bridge the amp to run the fronts and run the rear fill of the hu. You may need to fade forward if you get distortion though. Those Kickers are 4 ohm, so you can't get the 75 per with them
frysguy
frysguy
Los Angeles, CA
CSCStang
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
