Wire kits
danieldl
Hey,
I'm looking for a good wire kit to power my PDX-1.1000 plugged to my brand new Type-X. I actually have a 1 farad capacitor and some good quality 8-gauge wires and planning to get a good 4-gauge kit. Will it be enough or should I buy 2-gauge?
Is there any difference between a $40 kit on eBay an another $200 kit in-store?
Everything is plugged on my stock Toyota Yaris battery/alternator (which is about 80A I think).
Thank you!
Gauge 4 isn't enough? The guys on the subwoofer forums all said to get 4 gauge kit.
For the capacitor, why is it useless? My lights are still dimming with it but it's a little bit better with it. I thought a 10 or 20 farad capacitor would be the solution. A battery would take a little bit more space in the trunk, and I'm not sure I can plug it in directly to my car's battery without doing some electrical management.
Big 3 and all 1/0 wiring will be far more beneficial than that cap.
Well, is there anybody that can be really nice and explain me a little bit more why I need 0 gauge wires and no cap? On my Alpine boxes, it says to use 4 gauge. On the other forums, you guys told me that 4 gauge would me "more than sufficient". One line answer doesn't help me really much as you're all saying something different.
I wasn't really planning to get 0 gauge wires. It's so **** huge! Would there REALLY be a difference with 2 gauge? Or 4 gauge?
And I REALLY would like to know why I should get rid of my cap. If it's that bad, why is everybody buying these?
I really want to get real answers instead of "buy 0 gauge", "4 gauge will be more than sufficient", "get rid of your cap"...
4 ga is fine, people on here recommenced 0 ga when they barely run a set of co-ax
4ga will handle ~125amps of current
find a decent wire kit that you ,and that will fit your budget
I like kicker and Rockford
Knu if you are on a budget
17Ft 15.5mm blue power cable with 3/8" ring terminal
8Ft 9.5mm blue power cable
2 x 17Ft. clear RCA cables
20Ft. clear blue remote turn on wire
ANL fuse holder +250 AMP fuse
ANL Fuse power distribution block +2pcs 100 amp fuse
battery terminal
2x bright nickel ring terminals
2x18-22GA butt connectors
4x Bright nickel spade terminals
10x self -tapping screws
10x 6" cable ties
grommets
80 shipped //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif its more than u need and the cap since u have it should be fine. but a small 20ah agm is better than 100 1 farad caps and they are tiny 3 x 6 x 6 lolz
Okay, if 4 gauge is 125A, does it mean I need a 120+A fuse?
I was looking for this kit:
http://cgi.ebay.ca/POWER-ACOUSTIK-KIT-2G-2-GAUGE-AMPLIFIER-WIRING-AMP-KIT_W0QQitemZ140363316307QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item20ae4e3c53
It's 2 gauge but the fuse is only 80A, don't know if it's good or bad quality but it's not expansive. Anyone can tell me if it's good and more than enough for my PDX 1000? And then, should I keep my capacitor or get rid of it? I don't want my lights to dim too much, I'm open to buy a better one.
buy my last tsunami 4 gauge kit it will cost a little more to ship to you but it is a very good kit..for an extra 5 i will throw in a nice set of rca's..
Which kit are you talking about? I don't really need the RCA's, I already have a 8 gauge kit installed, I just need the power and the ground cables with the fuse-holder.
I can pay more to get an entire kit as it will be easier to sell my 8 gauge kit after but I won't get more than $20 from it anyway.
Tsunami 4 gauge kits on eBay sell with 60A fuse. Does it make a difference? There is one more expansive with 150A, but Tsunami specs are rating their kit up to 850W rms. It sounds like I would be better with 2 gauge.
i like these kits. excellent quiality. i reccomend these over the other choices. cant go wrong with this one
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
396
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
883
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
995
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
danieldl
danieldl
Quebec, Canada
danieldl
Decebal
    Jun 10, 2024
