wire amperage
  • 3
So its going to carry the same amperage at 12.5 volts that it will carry at 600 volts only because the distance is shorter? IDK about that it has to be less' date=' but I dont know the formula to covert it to find out.[/quote']
you understand current right?
if anything, it would handle more current because its a shorter length!
the voltage doesn't matter when it comes to current.
a 10amp, 120volt mains cable, will handle 10amps at 12volts...
the difference is, that 10amps at 120volts, is 1200watts, while 10amps at 12volts is only 120watts.
Not exactly. Im trying to learn. Thanks for the info. That really cleared it up for me.
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
400
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
887
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
995
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
Crownvicon28s
God 1st
Crownvicon28s
Spartanburg, SC
Crownvicon28s
Decebal
    Jun 10, 2024
