Will this amp work with these two subs
  • 6
[quote name='jungstah']DC level 3's may be in your range, don't quote me on that. @mylows10 can hook you up if interested[/QUOTE]
Not for 150 each. Might consider American bass subs I can sell you a Ab vfl 4480 for 320 shipped
Level 3's are above that. Check out Obsidian Audio for that price for the subs. New anyway. Might be able to get something better used.
For your amp, what kind of power you will need will depend on what subs you get. Check out the classifieds though, there's usually some pretty good deals. That RE will probably put out rated power though. It will just not be as efficient as a more expensive, better built amp. If you can find something better, you will be better off. Did I say "better" enough? //content.invisioncic.com/y282845/emoticons/nerd.gif.c6fa51ddf7ff75f1c0371fbc648f70ae.gif
You didn't say what subs you wanted actually. How much space do you have to work with? Don't forget about a box. Did you want 2 12', 1 15, 2 15's, etc.?
You said the subs are dual 4 ohm. Keep in mind that this means you have to wire them in series/parallel which will give you 4 ohms. Yes, the amp...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
Benj
Benj
Australia
Imtjnotu
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
