Will a disconnected speaker capacitor damage the speaker?
  • 2
momeigs
Makeshift Bass-head
The part circled in red in this photo came disconnected from the solder connection and now there’s no sound playing from the speaker. The capacitor all together is still connected but one end of the wire came loose. Didn’t know if playing music through the speaker while it’s disconnected could damage the speaker at all. Thanks 👍
If thats a coax, the tweeter won't play. The speaker will be fine most likely, but the tweeter, again, won't work. The cap is acting as a low pass filter for the tweeter.
Do not connect the tweeter directly without it. Solder on the cap, or a replacement cap, or replace the entire thing.
I connect my Amazon Echo Auto (Version 1 and now the new Version 2) to my Sony MEX-GS810BH via Bluetooth and set the MEX to Bluetooth Audio to...
Check for a blown fuse (or fuses). Referring to the car and not the amp. How do you have the amp wired? Power is directly to battery and ground is...
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
416
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
410
momeigs
Makeshift Bass-head
momeigs
Jacksonville
wew lad
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
