Who's good with Pioneer head units?
  • 2
Da64u
What's the deal with it being able to use the internal 18rms amp to power the speakers while simultaneously feeding the preouts for the amped speakers?
Every head unit I've had before you've had to choose one or the other. Will powering some speakers that do well with low power AND using the preouts to and amp induce distortion?
I wouldn't mind running 4 high power speakers off my amp and 4 low power speakers off my head unit if there are no negative consequences..
This looks like they went in and rewired some wires. 12 volts or a little less than 12 volts. When not enough volts are going through it, your...
6
You need to re-phrase the question. Are you trying to use active bi-amplification via outboard amplifiers or do you just want the recommended...
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
455
Da64u
Da64u
Fort Lauderdale, FL
Da64u
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
