White rust/powder appearing on speaker wire. JBL GX600C speakers
  • 3
serstylz2
CarAudio.com Newbie
Hey all, looking for your feedback. I installed all 4 JBL GX600C door speakers in my 2019 Infiniti Q50 with no issues last summer. I used the stock tweeters and did not use the crossover, only bought the 6.5" speakers. A few weeks ago my driver door speaker started cutting in and out and eventually was completely out. I took the door panel off and discovered the speaker had a white powder/rust buildup where it went into the terminal into the back of the speaker. I cut the rust off to expose fresh wiring and put crimped it into a new terminal. Here I am now, a few weeks later and the door speaker is starting to cut out. I suspect the same thing is happening. Should I scrap the speaker wire and try again, or could something else be the cause? Why would only my driver door have the issue when I used the same terminals and wire for all 4 doors? Did I possibly reverse the polarity and just need to fip my wires? Thanks for any help availalble.
I skimmed the manual and did not see any mention of a reset on that model, so bummer if leaving the power disconnected did not help. Maybe Pioneer...
10
4K
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
5
serstylz2
CarAudio.com Newbie
serstylz2
Charlotte
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
