when is a sub seperation/partition wall needed?
  • 3
buickv6
18
Canada
I am planning a ported enclosure for 2-12" subs. It has both subs facing up as well as both ports. I followed the manufacture specs for a single sub enclosure at 3'cu and just doubled the size and made a 6'cu box with two of the recommended ports instead of one. The newb question is, Do I need a partition wall making it act like two boxes?
Thanks
274
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
578
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
611
buickv6
buickv6
Canada
buickv6
