whats your ht sub
NO...
Benefits of some vs others.
The Q goes lower than the 12 OEM so does Blue Ray vs DVD. The Dynamo is more musical and sounds better with instruments but doesn't have the thumping low end of the Q or 12OEM.
But mostly I was bored and had the equipment lay around and wanted to use it.
I need to bring the amplifiers back from home, so it is back to Meyer UPJ-1P & EV subs for a while... //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Please? //content.invisioncic.com/y282845/emoticons/cuddle.gif.bd1b29c179c0482f8313dbd790b74c94.gif
Just messing with you, nice set-up.
how do your guys H.T. amps put out enough power for these things??? Most of the subs mentioned are like 500RMS-2000watts.... most H.T. amps only put out like 250-500TOPS for the sub channel don't they??
Pro Audio amps...
A lot of guys use the Behringer EP2500 for good cheap power.
Y'all have seen pics of them all, but:
Main HT: Dayton Titanic 3 off their 1000w plate amp
Bedroom HT: Dayton RS12HF off Bash 300
Dorm HT: Fi Q 15 off EP2500
All have their advantages and disadvantages.
Haven't actually put it together yet, but I have an Eclipse SW8200 and a Bash 500w ready to build. Will be in ~2.5 sealed with egg crate foam. Should easily pound the lows.
Speedbump: That IB install is insane.
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
3K
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
I think your front stage is spot on. If your DSP has a dongle that connects to your phone, then you are getting the full clear signal. No need to...
22
toolfan89
official ca.com shemale
toolfan89
your moms cooter
joetama
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
