What's a good 4 channel?
QueSound15
I know a thing or two....
Hey guys, looking to upgrade my 4 channel. I currently run an old scho USA made soundstream p205. Not enough power for my new components.
I need something 100rms to each channel at 4 ohms.
But my budget is around $100, maybe $150.
Anything worth buying in that price range?
try to see if woofersetc or online car stereo will pricematch, for a little more you can get the PPI 800.4 which is one of the most sought after 4 channel now 145w @ 4ohm and awesome crossover
---------- Post added at 11:10 PM ---------- Previous post was at 11:09 PM ----------
you can probably get an mb quart 125.4 at your price range
Why is the ppi so sought after? Jw
I would highly recommend to get a PPI Phantom P900.4. It's small efficient and powerful. The price is a bit higher than your budget, but the improvement over cheaper amps is real. If you want to spend less take a look at PPI Black Ice 4-channel amplifiers. They should do their rated power (I have seen a test of 800.4) and cost significantly less, but being Class A/B amps they're much bigger than the P900.4.
By the way, recently, I have been seeing a lot of places selling Alpine F300 amplifier for under $150. Vendors must be getting rid of their old stock (I think this is a discontinued model). These amplifiers are underrated by some 25%. They have very low noise, low distortion, high channel separation, they run very efficiently and take little space. Besides a bit more power, I don't know what one could ask for in this price range. Perhaps this is not a great subwoofer amp, but it will be sufficient for 95% of speakers out there.
PS: One excellent amp for under $100 is MB Quart REF4. These were quite good very clean output and quite underrated, but now discontinued. Some vendors still have old stock and sell them for a "song". I believe Sonicelectronix is selling MB Quart REF4.50 for like $90 and MB Quart REF1.800 for $110. The only issue with REF4 is that these are quite capable Class A/B amplifiers in a very small chassis. I have a REF4.80. It gets stupid hot in the summer. If put accidentally some cargo next to it that obstructs air flow, it can easily shutdown. I do like it as the sound is quite nice, and it was tested to provide 4x110watts RMS power at 4ohm (rated for 4x80). I suppose the REF4.50 is also a quite amp, but it will probably be sensitive to how you install it. The Alpine F300, being a Class D amp, should not have such problems. For this budget Alpine would be my top pick.
I have a Rockford PBR300X4 I got for $145.00 running my speakers. The birth sheet showed it put out 85 watts per channel at 4 ohms. Debating on buying a second one for the wifes car, but I've been searching around for amps in the same budget range of under $150.
Don't jack around and get a ppi phantom 900.4 . They are running 185.00$ on amazon or sonic. I am very pleased with mine very small amp too it can literally fit in the glove box. It's output is crazy as well I have it running 4 infinity kappas and it is more than most people can handle volume wise.
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
116
6
354
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
738
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
436
QueSound15
QueSound15
Bloomington, IN
bumpasauras
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
