What Was Your First Setup?
imaspaceguy90
LOUDS10BLAZER=SCAMMER
2,602
Melbourne,FL
Well im gettin mine together, but i kno there are some CA veterans or new memebers that had a first setup, wether it was a some Pyle subs and a Cuspid amp. What was your FIRST setup?//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Current one actually...still waiting to be installed
Pioneer deh-1600
Stock Rears
Stock Fronts
12" Type R
Interfire ifb-2340
2cubes@32hz
This has been done before.....several times if I'm not mistaken....
But for the record:
Coustic RX504 cassette receiver (dual-shaft style)
Pioneer 2-way 6.5 coaxials up front
Pioneer 3-way 6x9s in rear
Roadmaster 7-band boostilizer.....
mine wasn't to long ago, i had
a really crappy sony CDX-2010
a hand-me down 12" old rockford sub in a custom bandpass box my brother built that was tuned reallllly high
and a straight outta auto zone hand me down 200 watt Phase Linear amp
not really a full "system" but it's what got me hooked. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
uh....
power acoustik.. //content.invisioncic.com/y282845/emoticons/blush.gif.99bc659ee2012b7d826165e26fb5eebe.gif
ya know, the ones in my sig.... //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
oh! and my pioneer premier DEH 770! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
1971 F250 single cab 4x4
Some old kenwood deck
4 4" Infinity Kappas overhead
2 6x9's in lower doors running of kenwood 35x2 amp
2 JL 10w4's running on a PG XSsomethin' (200-250w?)
Imaging? Naw LOUD? ear piercingly but no boomy bass, they pointed directly into the back of the driver and pass. Single cab baby!
Well, I don't remember what exactly I had first but I owned some Craig, Kraco, Sparkomatic, Audiovox, Pyle(not bad back then), Mgt, Sherwood, Pioneer, Kenwood, Infinity, Polk, I'm sure there were other off the wall brands that I can't remember right now. The cheap stuff was owned when a 200w amp/Eq with flashing lights was state of the art stuff.
currently using RE components and xxx mids, with factory speaks rearfilling
had mtx 10"4500s; were upgraded to koda 10s last month.
mtx 801d sub amp, mxa 6004 4-channel for the fronts
cd1e v2 horns waiting for proper install:yumyum:
jury is still out on what HU i'll pick //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
currently using RE components and xxx mids, with factory speaks rearfillinghad mtx 10"4500s; were upgraded to koda 10s last month.
I wanan try those xxx mids
Alpine CDA-9827 (or something like that)
eDi 6500s
eD NINe.2
Hifonics BX1205D
Ava 15
But when installing the Ava and Hifonics, I switched to an Eclipse CD8053.
only been around the car audio scene a couple of years so here it goes. *deepbreathe* boss headunit 70x4!!!! and oversized 7 inch boss comp set and 5 1/4 alpine speakers found in a junkyard. the whole thing cost me 100 dollars, but 100 dollars too much.
91 crx si
aiwa cd palyer
doorspeakers outof a ford mustang :p
2 12inch pioneer IMPP (blue cones) (walmart)
oldass JVC 200 watt amp
and some 16 gauge power and ground wire....yessssssssssssssss (i was 13)
Quit talking nonsense and acting like you know something... It's ok to be new...ask legit questions and you can get legit help...but right now...
9
152
Don’t do it on the ground wire. If you lift the amps main ground and the amp tries to ground through the RCA cable shield, you can damage the head...
14
Check for a blown fuse (or fuses). Referring to the car and not the amp. How do you have the amp wired? Power is directly to battery and ground is...
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
692
imaspaceguy90
imaspaceguy90
Melbourne,FL
nauc
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
