What Sound Deadening Foam do I need?
  • 3
Zackster
Alabama
I'm running an American Bass TNT 15" in a 6cb.ft. box tuned to 28hz. I have both port and sub facing the hatch (I drive a Nissan Pathfinder 2001 SE 3.5) and, needless to say, the entire hatch flexes like crazy... especially towards the bottom with the licence plate. The rattling is especially loud at 40-50hz but not so much below that. Anyway, what type of sound deadening foam would you guys recommend I use on the hatch? And for some dumb *** reason my licence plate doesn't have bottom screws so I guess I could just shove some foam under it to stop the rattling there.
Use some weather stiripping foam on back of licence plate is got adhesive back so easy cheesy done lol . As far as hatch goes I have never had one but probably want butyl vib deadener maybe 2 or 3 layers and maybe a layer of 1/8 cc foam under the door panel itself and a layer of MLV on top of foam and door panel back on top of it all . Thats how I had to do most all of my truck and and its quiet AF and my doors hardly flex anymore as well as back of cab. If you need links to products I can send later and pics if needed Pm me.
Grab a few sheets of Second Skin SPL sheets and put them on the back of your plate. Then go to Walmart and go to the camping section. You can get 1/4" closed cell foam mats that go under sleeping bags for $5 a piece. Cut some small squares and glue a square on each corner and 1 in the middle of the plate. Rattles will disappear.
---------- Post added at 02:28 PM ---------- Previous post was at 02:27 PM ----------
25% coverage is all that is needed. After 25% coverage, you reach diminishing returns. Not 2 or 3 layers.
Ya I tried that one went with over 25 % first time doors still vibrated to beat hell went to 2 layers 80mil and three in the centers and even at 152 db doors dont vib much any more. Everything I read said 25 % but it sure didnt work for me ? maybe would work with smaller system too ?
I disagree with most. That **** is very sticky and only needs a quick wipe with isopropyl, assuming you aren't trying to adhere it to carpet or a...
33
3K
I’m very far from a car audio expert; one only has to see my recent posts around here to know that. I am, however, pretty knowledgeable on cars...
22
3K
1) That is correct. I bought mine from Amazon. Those were the actual links I used to purchase it. If you're budget conscious I'm sure you could...
Zackster
Zackster
Alabama
ChaseinBass
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
