What RCA cables do you use?
Im installing JL Audio FiX 86 this week in the 300. Any recommendations "best" RCA cables?
Anything "shielded" should be about the same. Don't put too much stock into marketing hype and over-pay. I'm currently using Monster and Stinger at the moment but have done plenty of installs with other brands and really unless you buy bottom of the gutter stuff (it'll look super cheap) you're fine. Even Boss brand RCA cables are fine assuming they're "shielded" and have decent enough insulation to survive mobile environment.
Stay away from the very cheap generic RCA's that look like this. They are the $2 bargain box specials..
Anything half decent that is shielded like stated will do fine.
I've never had a problem running the proper stinger rca cables or Memphis audio rca cables but the Memphis are harder to find now. The stinger work good and the price is in the mid range.
I want to get new ones with the cheaper ends. The style in my link grabs the RCA jacks so tight that the shield around the jack broke loose from my amp and got stuck in the RCA cable. No damage it just pushes back on but I was like wth
yeah i got some short nice ones with gold ends that screw tighten and they a pain to get off, i use them on ht..
No make or model number on it? Do you have an exact picture of the rear and all its glory?
808
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
817
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
698
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
813
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
922
znewberry
znewberry
Illinois
BOOMINGRANDPA
    May 31, 2024
    May 24, 2024
