What makes a subwoofer bottom out?
Bigmann6374
Moon, PA
Okay serious question here. I have a 15" Skar audio zvx-15 dual 2 subwoofer and I put it on 2 soundstream 2500s strapped to make 3400 watts rms. I started to test everything and kept hearing the **** sub bottom out at 30 to 40 hz and I'm tuned at 37! Now I understand that this is a 1500 rms woofer but I see SA-12s and 15s not bottom out on equal power. Why would a manufacturer make the sub hit bottom before reaching the limitations of the surround and I mean waaaayyy before. It really pisses me off because I have 5k on tap and countless hrs of work in this to power a 500 dollar paper weight. I had to drop back down to one rubicon 2500 and it seems thats all it will take period without mechanical failure.
Give me an option here, does the basket have a play in this? Does there need to be a spacer? Is the coil too long? What causes this?
Thanks!
Playing below tuning causes the sub to lose control. Lower tuning or reduce power
I'm asking physically what makes a sub bottom out.... Not from the power not from tuning... I just want what on the subwoofer makes a sub bottom out.
^^Yup this, since your tuned to 37hz playing down to 30hz is gonna make the sub lose control pretty easily. Especially if you don't have your subsonic filter tuned appropriately. My box for 2 SA-8v2's is tuned to about 35hz and playing rack city I get a crazy amount of excursion on the low note (29hz) because its starting to get a little farther below the box tuning than the sub likes. It doesn't bottom out but I'm sure if I tried to push it a little further it probably would. You need to build a more efficient and lower tuned box to be able to handle those really low notes better with that kind of power.
Either the spider/coil glue joint hitting the top plate, or the bottom of the coil hitting the back plate.
Also, if you don't believe you're reaching the full stroke potential before you're hearing noises, it could be coil rub and not coil bottoming. Coil rub should be a warranty issue.
---------- Post added at 07:15 PM ---------- Previous post was at 07:15 PM ----------
Maybe he listens to more rock/metal than rap? Doesn't a higher tuning benefit those styles of music more than a low tuning?
The Price is Right losing horn - YouTube
I have ability of changing ports out I made it aero ported. I have to make another 6" aero port and tune it to upper 20s like 27 for daily. But I compete in spl comps.
How does that tuning sound anyways? Is it only good for rap/dubstep/bass tests? How would that low of tuning sound with rock/metal?
See I have had coil rub and this is not that. The sub clings sounding like a hammer hitting a metal plate. The sub has so much more potential but is limited by poor engineering which really pisses me off!
I would clean the paint off that location and use two washers to sandwhich the ground wire to secure a solid connection and use a bolt rather than...
27
3K
Don't get me wrong I've built a few boxes myself and I love doing it and it would've been preferred. But I now live in a one bed room apartment...
42
9K
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
5
Unfortunately barly someone does these things in my country, and the ones that do, makes it so expensive to test it or even fix it that testing it...
4
ringer ringer, chicken dinner... its your headunit. gotta upgrade mine as well, does the same thing, it cannot handle the additonal speakers, just...
Bigmann6374
Bigmann6374
Moon, PA
TonWardHD
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
