What fuse for amps power cable?
  • 3
Drifter mike
CarAudio.com Recruit
32
Greece
Hello guys,
I bought today a 4 channel TRF M600.4AB amplifier and dont know what fuse to use for power cable. On the internet i have read that because my amp has 2 fuses 40 amps each, i have to use a 80 ampere fuse. But my amps manual says that i need to use a 40 ampere fuse. What is the right ?
Fuses do not protect amplifiers; fuses prevent fires. Fuse size is based on the size of your power wire. Whatever fuse comes with the amp kit is fine.
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
4
610
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
9
I plan on getting the fuse to run as a front sub/midbass in my kick panels...I've heard they sound good but you definitely wont get mirror shaking...
Drifter mike
Drifter mike
Greece
Drifter mike
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
