What do I need to connect to my head unit?
  • 3
Jtyson
2015 Ram 1500. UConnect 8.4 Alpine system. Need to retain all factory functions. Trying to attach my Crescendo 3500 to my Skars.
I've tried searching but either I'm not grasping or the answer isn't clear. I've seen PAC modules mentioned, amps with LOC, resistors, etc. What do I actually need? I found this other thread but his truck is newer. I tried asking on there but no response.
He said he connected an audiocontrol D-4.800 amp to his head unit which is the newer Harmon system. That amp is big $$$ and I wasn't banking on doing other speakers for a long while, if at all. But if that is the easiest way and is tuneable then I will buy that amp. I just don't know if I still need a PAC module to connect it? Or just the amp? Or something else?
I have emailed audiocontrol for answers as well. Shotgunning this here. I've had my box sitting in my garage for a couple weeks and I'd like to hear it work this year!
Well, that was half an hour I'll never get back. Zero reference to connecting an amplifier to a factory 8.4 Alpine Uconnect system. But I am confident in my ability to put speakers and an aftermarket deck in a truck that is totally different than mine.
Well I found another thread on here for a mega cab build being done by @txdog27 that mentioned integration with a PAC AmpPRO AP4-CH41. Amazon for $279. Man does that make me miss the days of a $60 deck and some RCAs. Oh well, times change.
And looks like I'll need a dsp as well for sound control, so I may go the route mentioned in that other thread with an Audiocontrol D-4.800 since that seems to be pretty flexible, even if it is a grip of cash I wasn't expecting to spend. But I'm not 100% sure on that part yet. Trying to keep it cheap with some subs and amp I had in the garage is turning out to be anything but that.
I’m not 100% sure but I think the Rockford Fosgate DSR1 can be used on your Ram. I used it on my Ford with the Sony system and love it. Super easy plug and play DSP.
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
443
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
352
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
390
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
600
Jtyson
Jtyson
Albuquerque, NM
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
