What are the RCA cables for in the back of a multimedia head unit?
  • 2
Elton20
I've been looking around for a good double din head unit, probably a pioneer avh series unit and I've seen that the back of it has the regular plug where I'm supposed to wire my harness and then there are female RCA cables. What am I supposed to do with those? I know I'm lame but I might get one to put in a 1997 Toyota camry or a 1999 Nissan quest
External amplifiers (Front/Rear and maybe Sub) and there's probably another set for a backup camera or additional monitors.
I know you didn't mention this, but the antenna will be the only other thing you plug in behind the unit besides the wire harness.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
880
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
920
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
767
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
859
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
947
Elton20
Elton20
Columbus, OH
Elton20
Decebal
    Jun 10, 2024
