what amp to use
  • 2
Cadence Z7000 Class AB Competition Mono Block Amplifier - eBay (item 290537155849 end time Feb-28-11 08:35:13 PST)
one of the best amps i have ever owned it is over 2 feet long but has some the cleanest best sounding power i have ever had. gives u the option to get another down the line
http://cgi.ebay.com/MB-QUART-ONX1-1500D-1500-WATT-MONO-CLASS-D-AMPLIFIER-/350442939809?pt=Car_Amplifiers&hash=item519806e5a1#ht_3199wt_1139Competition Mono Block Amplifier - eBay (item 290537155849 end time Feb-28-11 08:35:13 PST)[/url]
amazing product also gives u the option to upgrade down the line
SAZ-1500D SUNDOWN AUDIO MONOBLOCK 3000 W MAX AMPLIFIER - eBay (item 120607086018 end time Mar-07-11 17:22:25 PST)
if money is no issue
nope run it at 2 ohm 1000 watts, always good to have extra power, and if u want to add another dont need to change the amp. just dont put the gain up. do you have the old or newer models
put it to 1000 watts at 2 ohm and dont turn the gain all the way up, lots of times people get a 600rms sub and a 600rms amp and turn the gain all the way up to get the sub loud, but there pushing the amp to its limits and then ur sending a signal that clipping. that creates more heat and in return u get a fried coil. this way when ur turnign ur gain up you wont have to go that high and less likely to be sending a clipping signal. true way to set ur gain is with a oscilloscope
plus the new type r's have been know to take up to 800rms easy. they put a 3 inch coil in them, if your model has a 3 in it its the new one.
196
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
390
6
487
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
780
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
563
jjdsm
jjdsm
riverside,ca
jjdsm
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
