What Amp should I get?
I have two DVC Alpine Type-S 2ohm 10 inch subs that are rated at 600w RMS each. Just wondering what amp you’d recommend for me to get on a budget. I’d like to spend around $200 but will go higher if needed. Thanks
You should buy a Skar 1200 watt monoblock class D for your Alpine subs. Alpine Type R subs would be my choice..Purchased from Amazon is under $125. I'm sure you'll like Skar amplifiers and buy another from them again. Be sure to wire both subs correctly at 2 ohms or even 1 ohm to experience unbelievable lows.
Currently I'm running a Skar 12" dual 2 ohm voice coil sub with a 4500 watt monoblock amp. I connected it at 1 ohm with 0 gauge copper wire. My amp at 1 ohm will produce true 7000 watts and make a fire inside the car if I go full power. I will get pulled over and a ticket if I'm bumping it!
Your skar amp will catch on fire if you go full power?
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
Have you check to see if the prefab would fit...
13
For the sub you want to run.. The 700.1 will be more than enough power and enough Head room for that sub. For the Price? And the sub you are...
13
I'll suggest a JP8 amplifier. I believe you can wire your sub to 2 ohm. It's Dual voice coil 4 ohm, correct? JP8 @ 2 ohm does 900 watts.
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
Trudeau44
Trudeau44
New York
deez283
