What amp for (2) Fi BL 10's?
  • 6
doe boy
Just to change things up a bit this summer, I'm really impressed with Fi subwoofers and am seriously contemplating ordering 2 BL 10's to try out. Now I just need an amp to run them, any suggestions? Opinions are welcome //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
i ran 1 sudnown 1500d on 1 fi BL 12" and it was perfect. Buddy of mine runs an audioque 2200d on 2 bl 12's and it sounds great
Sundown Saz-3000D. I have 4 18's on two 3000's at .5 ohm each. If you upgrade the stock BL it will handle around 2000 rms, if you go much over that I'd go with the BTL's.
^^ like he said, im runnin 2 1500ds on 2 18s fully loaded. The guy with the 2200d already had the amp and he is changin to a 3500d soon
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
235
439
doe boy
doe boy
Alberta, CANADA
thericanballer
Decebal
    Jun 10, 2024
