well...fisrt comp of the season was yesterday
bgowdy
Heroes are remembered, but legends never die
i used the bb2400.1 yesterday for the comp. i was having a problem tho but i think we figured it.
not sure 100% but im oretty sure. i was in the lane competing and all the sudden my voltmeter goes crazy and amp is barley playing so for my first instinct is to shut on vehicle. i restart the truck and amp my voltmeter is showing 10.1volts while truck is running. so right off i check the alt and its reading 14.5v(normal), the i check the back batts and both read 14.5vnormal), however the amp voltage is reading 10.1v(WTF). i ran for a min and it got back to showing 14.5v at amp. so i tried again after checking wiring. and it shut down again and showed 10.1v. im thinking the problem was i had a double sided fuse block(holds 2 anls) ran to my amp with 1 250 amp fuse. we figured it wasnt getting a good connect there and we removed it after i got out of the lane from my run and we removed it. then we held a multi-meter on amp terminals and i ran it wide open to test it and it never shut down again with out the block being connected so i gess im not going to use a fuse. and the guy that had the block before said it was a sh1ty one(yea i know he could have said somthing before)........ anyone else had a problem from a fuse block connection or block just being sh1ty one?
thats wat said. i did notice the fuse holder was pretty hot wen took cover off, and yea its crazy. i removed it and did the exact same thing tested amp terminals
everything checked out fine with out the block. like i we tested everything seperate. alt showed 14.5, front batt & back 2 batts all showed 14.5, the amp showed
10.1. pretty much anyone that asked what happened and i explained, they were like, ?????? wtf????
That's why I don't run fuses anymore when competing they have cost me 1st place a couple of times but unless you are extremely knowledgeable and confident in your install I have to suggest running them though.
Depending on how much you value you your car I would rock a fuse a holder. I mean.. loose a first place or burn a vehicle to the ground. When I first started I was using a P.O.S schoche distro block completely unfesed. it would get so hot it would get soft (the plastic on the outside).
dude if im not mistakn it was a P.O.S. schoche dual distro block... im not home right now but im like 99.9% sure it is a schoche
im very confident. since i re ran all wire and got my big 3 done, this has never happened. i had another fuse block there before with different amp and never had a problem out of it. this is the 1st time this has happened.
this....
Did we get a score even with the issues??
yea... a horrible one... and i didnt want to buy back i was a bit pissed but i decided not to even bother with it.... dude when you gonna trade me that A7 lol
---------- Post added at 08:33 AM ---------- Previous post was at 08:32 AM ----------
yea like a 132.7db lmafo.....
Need 3k u get that and then we can talk..
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
9
583
Hi again, I appreciate all the suggestions and have my budget minded options down to 1 or 2 choices. I have noticed CDT, Image Dynamics and a...
bgowdy
bgowdy
Campbellsville, Ky
bgowdy
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
