Weird problem, bass cuts off randomly
  • 2
FurbiesAndBeans
Corona, CA
So this started about 1 1/2 weeks ago. What happens is that when the volume is low, the subwoofers won't even play, or they'll play for a while and cut off. But when i turn up the volume, the subwoofers start playing without cutting off at all. Strangely the same thing is happening with my HT set up. I thought it was the ipod being weird but i changed it to the CD player and it still does it.
I've checked everything, the amp is powering fine, the LOC is all plugged in. Then i thought it was my amp so i changed that, but still the problem's there. I even tried switching the subs for my dads set up and it still does it (different amp and sub).
I have no idea what it could be, any help?
Here's what i have at the moment:
Stock Radio
PAC LOC - Mazda One
Knu KLMX 4 gauge wiring kit
Directed 1100D
10" L7
Had this problem for a while.. But in a different manner. Turning it up made the subs play, but after a while, it would completely cut off regardless.
I guessed loose connections, and the higher signal strength helped keep it playing? Just a guess though. Sounds like the LOC out of anything, since that's the only thing not being swapped. And it's unlikely a problem with the stock radio.
Just throwing out things to check.
Yea i think it's the LOC too, maybe it wont stay on with a low voltage? I'm not sure. I think my rear speakers are going out and that might have something to do (LOC is using the rear speakers output)
id put the subs in a ported box, and buy the proper amp to push them
29
3K
Thanks for sharing the issue and sharing how to possibly fix any future issues for others
4
Yeah, somebody goofed. It was supposed to last 5. I have seen speakers fail at the solder joint on the cone under the black glue. But you are...
8
Sometimes the sound gets a bit lower, then gets normal again, only listening to FM radio. It does not do this when streaming music via wired Apple...
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
5
FurbiesAndBeans
FurbiesAndBeans
Corona, CA
FurbiesAndBeans
Decebal
    Jun 10, 2024
