Want to go Louder
Icecube91
I currently have 2 10" JL Audio W6v3 in 2cubes tuned to 30hertz and running off a JL Audio HD1200. I would like to get louder and also hit the lows a lot harder. Im thinking about getting a new setup that will be a bigger box and more power. These are the options below let me know your opinion.
2 10" Alpine X series in a 3 cubic box tuned to 32 hertz running off 1500-1800RMS
1 12" MTX 9500 in a 2.75 cubic box tuned to 32 hertz running off 1500-1600RMS
Last option I am not to sure as maybe the box will be too small.
1 15" MTX 9500 in 3 cubes tuned to 32 hertz running off 1500-1600RMS
buy new gear.   get a 3k and a sick 10, 12 or 15. or two 10s, two 12s on 3 k.    I would get a single 12 that can take the 3k, build a sick ported box and a 3k amp with a second or more battery.
what kind of car?
You could do 4 10s in a box with the same tuning on double your current power.
side firing subs, 2 per side, as big of a box as you can fit while allowing about 3in on either side for the subs to load and a big 6-8 inch aeroport rear firing.
I metered a guys 2 door grand am with 4 xfl tens on 2 vfl audio 4480 mono amps, probably 2200w rms, box was tuned to 34hz and it did 148db on music and played pretty flat down to 146 at 30hz.
I dont want to give up my whole trunk. I work on it some more tonight. I think my JL Audio Fix86 is whats causing it  not to slam. First its not calibrating properly and second I think the Fix86 isnt sending my amp a good signal. I did a test where I took the RCAs out and did RCAs to headphone jack and I played music and it played soo much better.
On a side note if I did change woofers the  2 10s Alpine X would be louder but the single 12 MTX would play the deeper bass a lot better?
I use to have a 13w7 in my car running off the same amp. It wasnt as loud but it hit the low notes better. Maybe going a bigger box will help with deeper bass? Its in 2 cubes net right now so 1 cubes a sub. Was thinking of maybe doing 1.25 - 1.5 per woofer? Any recommendations?
Yes, I have a difference, but my difference is HUGE. The difference can be so big, as if I had a sound system in about 150-200 dolars (with wires...
41
9K
im not looking to seal off im trying to stay out of wall classes and plan on staying in trunk classes
15
3K
What are some of the louder, while still sounding good, 6.5" sets out there? Been looking at some of these higher powered Sky High Car Audio sets...
My subs unload at full tilt @ 28 hz, They are in 3.69 cubes net tuned to 34 hz. 4 - 8's. Big box and big power.
7
Icecube91
Icecube91
Vancouver, BC
MattinMO
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
