W7's, ohm's, multiples..
  • 6
3 3 ohm loads in parallel is 1 ohm. Take the reciprocal of each impedence add them up and the reciproecal of that is your answer.
3 ohm load is 3/1 So you take 1/3 + 1/3 = 2/3 flip that and you get 3/2 ( or 1.5 for 2 of them) for 3 of them you do 1/3 + 1/3 + 1/3 = 3/3 = 1
Q.E.D.
Q.E.D.
That sums it up. Thanks.
Now the 13's are D 1.5.. would two of them equal out to .75?
you could series wire the coils on each of the subs to 3 ohm. And then you could parallel wire in the 2 subs which would give you a final result of 1.5 ohm.
if you parallel wired everything then you would get .25 ohm
you could series wire the coils on each of the subs to 3 ohm. And then you could parallel wire in the 2 subs which would give you a final result of 1.5 ohm.if you parallel wired everything then you would get .25 ohm
4 1.5 ohm coils in parallel would be .375 ohm
Daym. My SAZ would be making some serious power //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
It also lowers the amps efficiency and raises the current draw.
5
683
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
484
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
boomzabit
boomzabit
Minnesota
Digital Designs
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
