Volume up, Bass gone!!!!
Well, You could have accidently touched the positive to the case of the amp which is also a ground and would more than likely blow the fuses in the amp. Check the fuses in the amp and also the one under your hood. (assuming you have one of course).....
how do i wire them to a hire ohm
Don't listen to that kid, he's an idiot. First and foremost, whenever your working on ANY kind of electrical wiring in your car you need to disconnect the battery. Having your positive wire in the amp be live when you stuck the ground back in there is a no-no. Next, I assume you have a multimeter (if not, go spend the $5 at walmart and get one). The easiest thing to start narrowing down what's broken is to check voltages. Check the voltage at your amp, if you still have +12V on your power wire and remote turn on, but the amp isn't turning on, then you know there is something wrong with the amp. If your not getting 12V at the amp then you know there's a problem in your power wire somewhere (probably a blown fuse or bad connection somewhere)
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
ringer ringer, chicken dinner... its your headunit. gotta upgrade mine as well, does the same thing, it cannot handle the additonal speakers, just...
Yeah I did remove the base cap and just straight wire you know grounded to amp and everything how it originally was before the base cap and it...
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
269
Marquise
Marquise
fort worth, tx
quins90lac
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
